Ignition Coil connections on 110CC China model
Old Aug 20, 2007 | 06:51 PM
richarddhardy's Avatar
Default Ignition Coil connections on 110CC China model
Hi all,
I, like others, recently bought a BMX model ATV for my son. it is a 110CC unit. After 2 days of riding, it seems that the ignition coil came loose from where it was bolted on the frame. There are two wires, black and green, on the opposite side of the coil from the spark plug wire. These two wires are male connectors but i cannot find where they should be connected. I assume that one or both of these actually deliver the spark so without them the unit will not start.
I do see one female connector that is loose in the same area, but it is a half green half black wire. Does anyone know, or if you have one of these machines, can you trace those wires and tell me where they should go? The ignition coil looks to have been mounted on the frame in the right front wheel well area. Any help would be apprecaited.
Thanks.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Aug 8, 2015 05:49 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
