scrambler 50 help
Old Aug 21, 2007 | 10:09 AM
tunerskip's Avatar
Default scrambler 50 help
i have been working on a scrambler 50 motor will start run for a few seconds then dies like it is running out of fuel pulled the carb cleaned checked the reeds checked fuel flow everything seems ok and now on top of the previous problem i dont think it is firing any help would be appreciated
i have worked on several quads and bikes and this thing has me scratching my head
Old Aug 21, 2007 | 12:33 PM
chuck_norris's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tunerskip
i have worked on several quads and bikes and this thing has me scratching my head</end quote></div>
Have you checked for good spark, spark plug and compression? you may have washed the rings down. as to the starting and stalling out, check out the idle screw and or mixer screw
Old Aug 22, 2007 | 08:02 PM
powerfool's Avatar
Sounds like you're having the same problem I'm having with a 2-stroke Aeon Cobra 90. What I found on mine is I think the electric choke isn't working. Not having any documentation on this thing, I have no idea what the operating principles are behind it. Is there a temp sensor somewhere or is this activated automatically based on some other event or what? I do know that it runs great it I take the air filter hose off and choke it with my hand just right, letting just a minute amount of air in. That said, I've tried doing that for a longer period of time until the motor should have been warm enough to not need the choke and it still dies after a few seconds. This thing only has one screw on the side and it's the idle speed so there's no mixture adjustment (at least not with a screw).
You could try choking it with your hand like I did to possibly eliminate spark or fuel supply related issues.
Old Aug 23, 2007 | 09:44 AM
powerfool's Avatar
OK, well just wanted to update since I got mine running last night. The electric choke plunger is working. When testing before, what threw me off was the fact that it does not get voltage from the battery but from the charging circuit. In other words, while cranking or running. With this in mind, I had to dig a little deeper since I knew it wasn't getting enough fuel one way or another. Turns out this thing DOES have a mixture adjustment. Not sure how I missed it the first time. I took the carb apart again, removing the screw and spring and all so I could clean it out real good. Now with it all back together and tweaking on the mixture adjustment, this thing is running great!
Old Aug 23, 2007 | 09:55 AM
tunerskip's Avatar
well i went to the local polaris dealer they told me it is probably the eclectric choke causing the problem but at $174.00 dollars thats a big maybe i asked about a manual choke conversion they said no such thing i do know now that my air screw is to far out i wont have a chance to mess with this thing untill this weekend since i have football practice everynight and cub scouts on top of that any more help would be appreciated thanks to all who have replied
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
