polaris died
Old Jan 2, 2001 | 07:21 PM
jbark35's Avatar
i was wondering if anyone had this problem iwas riding in the snow the other day and it just died all of a sudden i checked the plug and its ok kind fells like when i pull the rope there is little compression i have a weisco piston and a hotseat head both with very little hours on them does anyone have any suggestion on what to check
Old Jan 2, 2001 | 07:46 PM
ATV_MAN's Avatar
Check to see if- you have any gas(lol), battery, oil, kill switch might have been hit, could be anything.
x_scrambler3's Avatar
It sounds like it might be running lean an the piston is burn out the way to check it is to remove the pipe an look in the cyclender an turn it over. My friend had the same problems but his was doing because it didn't have high enough octane
Old Jan 2, 2001 | 08:47 PM
PolarisMan's Avatar
Yeah, i was on a honda 300 once, and it just dies, i was like OK. So i get to looking, and i hit the kill switch, easier than u think, ecpesially hondas
Old Jan 2, 2001 | 09:22 PM
scramdaddy400's Avatar
I can tell you what your problem is right now, the same thing happened to me and it has nothing to do with you compression.
It is the spark plug the stock b8es is to hot of a plug to run in the winter go up to a cooler plug. In my scrambler for the winter I'm running a br9es, now I can torture it without fear of it dying.
What happens is the plug your running now gets hot to the point where it cant spark right, in return your machine dies.
REMEMBER: NGK BR9ES
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Jan 2, 2001 | 09:32 PM
Xplor's Avatar
Spark plug thing...Mine did the same and I got the BR9 and it works great now!
Old Jan 2, 2001 | 09:39 PM
Glad I could help Xplor, now go show your buddy Zorro who's boss in the snow!!!
SCRAMDADDY400
Old Jan 2, 2001 | 09:54 PM
NewDSLover's Avatar
jbark35, when it died, did it backfire? We were out New Years Day, I on my new DS and my brother on my 400 Scrambler 2x4. I was behind him when I heard a backfire and the quad stopped. I went up to him to see what happened. I tried to start it, then I pulled the pull start and it felt like nothing. This morning I tore into it and found a piston failure, not lean, filter was ok and coolent was ok also. It was on the outlet side also. Called the dealer and he has a .10 over wisco instock and can punch it out tomorrow for me. It'll be back up for this weekend.
Jbark35, using the pull start cord. Try and pull a couple of time, if it pulls real easy. You know the deal. Also, pull the plug and check it, put your finger over the spark plug hole and pull start it again. It should have a strong Suck & Push feel to it. Good Luck!
Old Jan 2, 2001 | 10:19 PM
jbark35's Avatar
thanks for the comments guys i put my finger over the sparkplug hole and it was barely pushing my finger off so i guess ill have to tear it down again thanks again for your guys suggestion
Old Jan 2, 2001 | 10:24 PM
Xplor's Avatar
He already knows scramdaddy! LOL
Seriusly though...we are supposed to go snowmobiling tomorrow, last saturday he seized the motor and is doing a rebuild! Let the snow-sled shootout begin!
Brian
