polaris died
The old stuck ring piston seizure syndrome. Bummer!
Now to analyze what caused the seizure.
Did you start the engine and immediately run the quad? If so that is called a cold seizure, caused by the piston expanding faster than the block.
Were you running summer time jetting in your carburetor?
Or, were you running a different type of two stroke oil which caused the rings to stick. Caster Bean Oil can do this to a two stroke in the winter. Sometimes by gelling in the resevoir.
Or, how about a high speed run down the lake or river with lean jetting. Backing off of the accelerator without blipping it a couple times.
In any event, if you can stay away from the Wiseco pistons if you can. Most people can't buy just one. Good luck.
KimSJoh
14
Jul 18, 2015 07:20 PM
