to much oil
Old Aug 22, 2007 | 08:46 PM
4OOEXRIDER's Avatar
Default to much oil
hey i need some help im a city kid who got thrown in to the country and bought a four wheeler and dont know **** about it i have a 04 400ex and my bro put to much oil in it and its burning oil like insanely so do i take out all the oil or what help please
Old Aug 22, 2007 | 09:21 PM
chenoweth122's Avatar
Default to much oil
yes, i would drain it immediatly. hope fully you did not blow any seals. if it is not leaking oil after running it, thatn drain all out. i would also turn it over when you have the oil cap off. don't start the motor but just crank it a little and it should spit the majority of it out. than refill with the right amount and hopefully no damage was done.
Old Aug 23, 2007 | 01:00 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default to much oil
Usually when you overfill these, the pressure will blow the lines right off the oil tank! Like he said, hopefully you have not blown out any of the seals.
http://www.atvriders.com/articles/oilchange400ex.html
Old Aug 23, 2007 | 08:25 AM
HondaTechnician's Avatar
Default to much oil
Overfilling the engine with oil ahould not cause it to "burn oil insanely".
I have saw these units with up to 1 to 2 quarts to much oil in them with no adverse effects. People check the oil on a cold engine and it will always check low on these models. The engine needs to be warmed up and idled for about 5 minutes before checking the oil level. A cool trick when filling these units is after draining the crankcase and oil tank, changing the filter, when refilling, fill the oil tank to the very top, and your oil level will be just about perfect after starting and idling through.
Old Aug 23, 2007 | 10:06 AM
Red Rider
Default to much oil
If it is smoking, most likely it's valve guide seals. But also be sure it isn't your rings, by doing a compression test and leakdown test.
Old Aug 30, 2007 | 04:44 AM
4OOEXRIDER's Avatar
Default to much oil
how do i do a compression test do i have to take it in or can i do it
