pooched shock can it be repaired can I use pump air instead
Old Aug 26, 2007 | 05:17 AM
mrclark's Avatar
Default pooched shock can it be repaired can I use pump air instead
The rear shock on my 2001 DS seems to be out of commision. When you press down on the bike the *** end just jump flops up and down.
It does hold the bike in a upward position but when you hit a bump it almost bounces you off from the constant mushy rebounding.
It doesnt seem to be leaking oil and I was wondering is it common to need to recharge these with nitrogen every 6 years or so.
I checked the reservior and theres no gas in it.
I have another used shock on order but I was wondering what would happen if I just went to the gas station and filled it with air from a tire pump?
Will it damage the unit if its just out of nitrogen?
Reason I ask is I took a bicycle pump and filled it a bit and noticed a bit difference for a short period of time that is.
Old Aug 26, 2007 | 02:19 PM
Hightower's Avatar
you cannot charge a shock rezzy with air - for at least two reasons,
first it gets multi thousand psi of nitrogen, so no air compressor can even do it justice,
second its prolly not a good idea to have air/oxygen in this type of shock because it may turn the high temp oil into a pressurized molotoff coctail under your ****, maybe blow you kingdom come
Old Aug 26, 2007 | 03:03 PM
mrclark's Avatar
Well I need my **** its served me well over the years, thanks for the info.
I guess I'll just go and get someone to refill it.
I thought it only took about 300 psi am I right?
Oh ya and are all the years of the DS the same meaning will an 06 shock fit on a 01 and is the procedure of removing the shock fairly simple?
I looks like just a few bolts and screws and thats it in the shop manual?
thanks
Old Aug 27, 2007 | 11:36 AM
mrclark's Avatar
found another shock cheap, ordered one off ebay and it looks like I got screwed, but I found another. (long story)
anyhow will an 06 shock work on a 01 ds650
Old Aug 27, 2007 | 08:22 PM
DuneRider650's Avatar
I ride a little here and there......
im pretty sure it will.....the swingarms changed in 04 but i think the mounting brackets for the shock still are the same.
Old Aug 27, 2007 | 08:29 PM
DUNEKING01's Avatar
I've always heard to charge the rears to 200 psi nitrogen. thats what i charged mine to and am happy with it.
Old Aug 28, 2007 | 10:49 AM
Hightower's Avatar
yeah I think you guys are right, I thought it was over a grand for some reason, but 2 or 300 sounds more like it.
I've had shocks redone before, had a local bike shop charge for me, I just remember it was more than air compressors can make.
I do remember a distinct warning I read in one of my older honda manuals about using air instead of nitrogen,
yes indeed any model year ds shock is interchangable with others, I know a few people who changed from one swinger to the other using same shock with no issues.
Old Aug 28, 2007 | 04:31 PM
Old Aug 30, 2007 | 02:45 AM
mrclark's Avatar
does anyone know of a shock repair kit for the DS by the way? I hear there pretty cheap
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
cboler9
Sep 24, 2015 08:35 PM
Sw00p
Sep 24, 2015 02:50 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
