2001 fourtrax 350
Old Aug 26, 2007 | 12:46 PM
rodmon's Avatar
Default 2001 fourtrax 350
i have a 2001 350 fourtrak that keeps blowing main fuse so the bike is dead cant even put fuse in without it blowing any body know which root to go .
thanks
Old Aug 26, 2007 | 02:34 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You still should be able to start it with the pull starter. Everything should work except the starter and the lights.
It happens sometimes that the insulation will get rubbed off a wire or it will get kinked, and cause a short. I would start from the fuse, and trace the wires out, looking for shorts. If it even happens when the lights are off, then it maybe in the ignition circuit????
Old Aug 26, 2007 | 03:09 PM
Gimpster's Avatar
A few more things to check. Right rear fenderwell is the voltage regulator, unplug it and inspect for damaged wires or moisture. Also, up front, chase back the shift control motor wires to it's connector (should be a round white connector with 2 wires going to it) unplug it and turn the ignition switch on. Check if the fuse blew with the white connector unplugged. Make sure the battery cables are connected the right way on the battery (it is easy to install the battery backwards and hook up the cables, still)
-----gimpster-----
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
wendal
Oct 31, 2017 03:31 AM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
