06 RANCHER ES TROUBLE
Old Aug 26, 2007 | 01:49 PM
djgstang's Avatar
Default 06 RANCHER ES TROUBLE
WHEN THE BRAKES ARE APPLIED THE BIKE SHIFT INDICATOR STARTS BLINKING TWICE AND I CANNOT SHIFT THE BIKE UNLESS I TURN IT OFF AND ON. IF I DISCONNECT THE THE 3 BRAKE LIGHT RELAY'S( 2 ON HANDEL BAR AND 1 ON FOOT BRAKE) THE BIKE WORKS FINE. HOWEVER I DON'T HAVE BRAKE LIGHTS. I FOUND THAT THE CODE IT'S BLINKING MEANS CHECK ES. SOMEWHERE THERE MUST BE A SHORT WHEN THE BRAKE LIGHTS COME ON. I HAVE TRIED HOOKING UP THE BRAKE RELAY'S ONE AT A TIME TO SEE IF IT WAS ONE OF THEM CAUSING THE PROBLEM, BUT IT STILL DID IT. ANYONE ELSE EVER HAD THIS PROBLEM?
Old Aug 26, 2007 | 02:14 PM
wowkoolaid's Avatar
hey djgstang my son has the same bike with the same problem i am tring to find out the problem also so if u find it let me know and if i find it i will let u know
Old Aug 26, 2007 | 03:02 PM
Gimpster's Avatar
If you look in the right front fenderwell, past the inner fender, there is a row of connectors. Unplug the big green one. For ease of doing this I remove the rack and front fender. Once the connector is unplugged, clean it by spraying a electrical cleaner (not brake/contact cleaner), a tuner spray. Blow both male and female connections with compressed air and reconnect. Remove the seat and do the same to the ECM connections. The problem should go away.
If not replace the left handlebar switch assembly. On units that I have replaced the switch assembly, I have not had time to trace the wires back to find the problem within the switch assembly itself. Been busy backloaded with goldwing cruise issues and farmer/rancher's units since it is harvest time, to find the root of evil. They say moisture in the connector has been the culperate, I have not been able to confirm that diagnosis.
-----gimp-----
Old Aug 27, 2007 | 12:37 PM
djgstang's Avatar
Cleaned the plugs like you suggested and it worked like a champ.
Thanks,
Dave
Old Aug 31, 2007 | 09:50 PM
Tickledblue's Avatar
Hello,
I have a 2000 model Rancher that has ES problems. When I get ready to start sometimes it won't go to neutral. I have to get the wrench and put it in manually. Then when it starts I have to put it in gear. Sometimes it will go on and shift to other gears, sometimes it won't. You sound very sharp on these and I would really appreciate your help. The dealer can't fix it so far. Thank You
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
