scrambler 500 backfire
Old Aug 26, 2007 | 06:16 PM
auto2tech1999's Avatar
Default scrambler 500 backfire
i got a 2000 scrambler 500 4x4 backfires on slow down after full speed its all stock with k&n air filter any help
Old Aug 26, 2007 | 07:30 PM
embler's Avatar
my sportsman 700 does the same thing every once in a while. does yours do it all the time? check your spark plug and also clean out the spark arrestor. also check your carb, it may be running too rich causing it to load up
embler's Avatar
Old Aug 26, 2007 | 07:41 PM
scramblerXrated's Avatar
a backfire under de-acceleration usually indicates a lean condition. you can adjust your needle setting to richen it up a bit, see if that helps. mine did it until i replaced the stock pilot jet #40 with a 42.5. went away after that.
Old Aug 26, 2007 | 08:29 PM
thanks ill try changing the jet like you said.ill try anything im at my witts end it backfires all the time
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
