2005 Honda Rancher
Old Aug 26, 2007 | 10:11 PM
daffy's Avatar
Default 2005 Honda Rancher
I have a 2005 350 Rancher that only has 52 miles on it . Its been in a garage and the battery went dead. I purchased a new battery and now it will not shift. It has the push button shifter on the handlebars. I can shut the key off and it will shift for a while and then it stops shifting, until I shut the key off and turn it back on again. Does anyone know the reason for this?
Old Aug 27, 2007 | 12:47 AM
Gimpster's Avatar
Make sure the battery bolts are tight with a wrench, not a screwdriver, and the cables are not loose. If you still have a problem shifting with the ES, have your Honda dealer check if your vin number falls in the angle sensor recall. Have them replace it and your shifting issues should end
-----gregg-----
Old Aug 27, 2007 | 08:25 PM
daffy's Avatar
I checked the battery cables and they were fine, so I called the Honda dealer and found out there is a re-call on the shifting. Thank you very much.
bigred20653
Aug 31, 2015 12:41 PM
colt1126
Aug 18, 2015 10:38 PM
Scottma518
Jul 16, 2015 09:19 PM
tporath
Jul 11, 2015 12:31 PM
Scottma518
Jul 10, 2015 12:42 AM
