Electric problem with 2001 Honda foreman
Old Aug 29, 2007 | 07:49 PM
wayleb's Avatar
Default Electric problem with 2001 Honda foreman
When I turn the ignition the lights show me R and N at the same time. It will start but the electric shift won't work. I tried changing to a New ignition and same problem. Fuses are fine? Thanks in advance for all the tips.
Old Aug 29, 2007 | 09:38 PM
Gimpster's Avatar
Sounds to me like a gear position switch is bad or the wiring is shorted
-----gimpster-----
Old Aug 30, 2007 | 06:17 AM
HondaMechanic's Avatar
Did you check the gear position coupler and the coupler for the dash for water/moisture ..
Old Aug 30, 2007 | 03:05 PM
wayleb's Avatar
I forgot to mention that when I bi-pass the ignition, meaning putting all ignition wires together, it works great! The last time I went out I used an electrical "Marrett" to keep the wires together and the electric shifter worked great the whole week-end! Thanks
neilbedwell
Nov 10, 2018 11:02 AM
neilbedwell
May 31, 2015 11:11 AM
MyDawg01
Apr 25, 2000 10:01 AM
lovinhonda
Jan 25, 2000 09:17 PM
Joeg
Sep 27, 1999 11:53 AM
