2006 Rubicon Idle problem???
Old Aug 30, 2007 | 12:56 PM
Endmile's Avatar
Default 2006 Rubicon Idle problem???
Hello-I'm new to the site and new to owning a 2006 Rubicon. This is a brand new machine with .3 miles on it. For some reason when it is in auto, when I come to a stop it stalls out. It seems as if the idle is too low, shouldn't this have been taken care of in the dealer prep before it was delivered? Or is this normal, I have never had an auto before. Or can I simply increase the idle. If so how?
Thanks,
Endmile
Old Aug 30, 2007 | 04:48 PM
HondaTechnician's Avatar
I believe that machine should idle at either 1200 or 1400 RPM, not sure how to tell you to get that without your having a tachometer.
Old Aug 30, 2007 | 05:37 PM
rockhazard's Avatar
I've had my rubicon for over a year and drive the hell out of it have never had any problem with it idling. I would take it in if it is new, that should be there problem.
Old Aug 31, 2007 | 08:51 AM
Endmile's Avatar
Thanks for the advice!!! Is it pretty easy to increase the idle. I should probably just take it in seeing I have only had it for 2 days.
Old Aug 31, 2007 | 10:09 AM
colt2245p's Avatar
the idle adjustment is on the right side, remove the seat and the right panel and its a **** on the side of the carb. turn it up some just make sure it doesnt creep in gear or lurch when you shift
Jmuddin284
Jan 19, 2026 07:16 AM
hugemoth
Jul 20, 2020 03:28 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
