Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
idles then no power
Old Aug 31, 2007 | 12:33 AM
MNYamaRider's Avatar
Default idles then no power
I have a 2001 Yamaha Wolverine 350. The other day I just lost power while riding. It will idle fine but when you throttle up it spits gas back out of the carb into the filter in a fine mist. Replaced the float needle and seat. No help. Definetly seems to be in the carb. Need Help!
Old Aug 31, 2007 | 11:25 AM
BradW's Avatar
I'm assuming that if you replaced the needle and seat that you thoroughly cleaned the carb. If so, I don't know, but it really sounds like your main jet is clogged or there is crud in the float bowl. I've run into this on a bunch of different machines and that is always what it has been.
Old Sep 1, 2007 | 12:04 AM
I found it last night after reading it in some other older posts, it is the parking brake. The thing is junk and hasn't worked since I bought it. I was loading wood in a trailer on a hill and thought I would give it a try. Imagine my surprise when it didn't, so my wife held the brake while I loaded the trailer. Last night after reading the post I went out and looked under the rubber boot that cover the parking brake actuator/lock and the cable was out about an inch. Pushed it in and she runs like a champ again. This thing provides a feed to the CDI and prevents high rpm to keep you from burning up the brake. Great safety feature that works poorly. Thanks for the help !!!!!!
Old Feb 1, 2008 | 07:54 PM
riptide777's Avatar
do you know if a 350 warrior would be the act the same way.
Old Feb 2, 2008 | 08:13 AM
My guess is yes. I think main differences are carb size, shaft drive and 4 wheel.
Cole Hadden
Jun 15, 2025 09:05 AM
scram5050
Aug 30, 2024 01:39 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
tweeder
Jul 5, 2015 01:57 PM
