Polaris Interchange
Old Aug 31, 2007 | 03:33 AM
wwhijr's Avatar
Default Polaris Interchange
I have a 98 Xplorer 300 that I bought this week. Once I got it home and was taking a slow ride down the hill to put it in the barn went wide open and crashed into a large piece of machienery in the field. I have discovered that the previous owner worked on the throttle cable and it hung at WOT. I escaped with minor injuries, but the atv is smashed badly. It needs a complete front end suspension and bodywork. Does anyone know if parts from any other models will interchange with it. I have found a 97 400 xplorer for cheap that needs an engine and had good front end parts. If anyone can tell me if any parts will swap over I would appreciate it.
Old Aug 31, 2007 | 04:17 AM
dosceola's Avatar
When the years are close they will 9 outta 10 times unless they changed the model design. all u have to do is look at other quad and u will see if they interchange or not. most times models will have bigger or smaller engine but frame and suspension will be same. your eye should be able to tell if they will cross over or not.
Old Aug 31, 2007 | 08:03 AM
ftwflh's Avatar
Check the parts here http://parts.polarisind.com/Browse/Browse.asp
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
lightninboy
May 16, 2021 09:52 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
