HELP
Old Sep 6, 2007 | 07:47 PM
polarisportsman800's Avatar
Default HELP
Hello im havin troubles removing my a-arm from my bottom shock/hub. been using a tie rod remover for a ttruck so its a bit big , but one concern is my rubber seal on the shock/hub will get damaged andy ideas?06 sportsman 800
Old Sep 7, 2007 | 12:19 AM
ftwflh's Avatar
Default HELP
get a bigger hammer! You shouldnt hurt the rubber it is only a dust seal.
Old Sep 7, 2007 | 12:39 AM
Default HELP
yah i did go get a bigger hammer and a piece of wood and after a few hits it poped off , now im having trouble pullin the spindle thing of the end of the cv ive been just tappin with no luck
Old Sep 7, 2007 | 02:58 AM
dosceola's Avatar
Default HELP
<div class="FTQUOTE"><begin quote>Originally posted by: polarisportsman800
yah i did go get a bigger hammer and a piece of wood and after a few hits it poped off , now im having trouble pullin the spindle thing of the end of the cv ive been just tappin with no luck</end quote></div>
---- use some heat on end of CV. propane torch works good. wood block on end and give er a good thump
Old Sep 7, 2007 | 03:02 AM
dosceola's Avatar
Default HELP
Any of u 800 guys have a lot of noise in front end when rolling? I changed fluid and my drain plug magnet was heaped with metal frag, like quater inch high.
U know how things sound diffrent if u dont have helmet on,but now i hear noise with it on. not a grinding noice just lots of clatter. might just be me cause i cant find any problems
Old Sep 7, 2007 | 05:07 AM
Mud Hog's Avatar
Default HELP
I am on my second 07 800 this year and both of them have clatter in the front end. I think I was told that it had to do with the ebs system and was nothing to worry about.
Old Sep 7, 2007 | 07:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default HELP
any noise your hearing isnt from the ebs. its the slap,black lash, or slop or anything else you want to go it in the transmission. if you take the bikes rear drive shaft w/ it sitting on a flat level spot w/ it off in neutral you can rock it back in forth and actually hear/see the slop in the black lash. the ebs shouldnt be making any noise. not sure what your trying to take out, but if its the cv shaft from the housing it just pops out w/ a good jerk.
Old Sep 7, 2007 | 09:31 AM
ftwflh's Avatar
Default HELP
Get a BIG dead blow hammer and smack the cv.There is a springed snap ring you have to get over.
Old Sep 7, 2007 | 10:24 AM
sheepdogMSP8117's Avatar
Default HELP
No noises from the front end of my 800. I do have the usual amount of driveline lash/noise, though. I also have a moderate fast-paced knocking noise coming from the right side of the engine near the case, only when fully warmed up and only under 2,000 RPM. I'd be worried about it if it didn't do it since it was new, or if I had the only 800 that made this noise. I'm not the only one am I??
Old Sep 7, 2007 | 07:21 PM
Default HELP
would it be easier to take the whole shaft out , since all i am trying to do is put a new boot on(the low part of the shaft closest to the tire)im trying to get the universal part off of the shaft so i can put my new boot on.now how do you tap the universal part off of the shaft? someone told me there i a clamp ring behind thestar part on the universal or is that the end going in to the diff? im havin troubles ive found a site that i can download the sevice manual but im on deial up and it would take me 15 days to down load thanks for the help
