250x question
Old Sep 9, 2007 | 12:10 PM
tdye's Avatar
Default 250x question
hi all. Finally got the bike to spark, had to replace the wire harness the old one was butchered beyond compare. Previous owner has removed the key switch and the run/kill switch and replaced with a tethered kill switch. I believe the switch may be bad. Should the bike run with those wires wired together or with them not hooked together. Also while working on the bike I pulled the left cover off to remove the stator and was wondering if there should be oil in there? The stator and flywheel were covered in oil. This would make it hard to start, right? ANy ideas?
Old Sep 10, 2007 | 06:05 AM
HondaTechnician's Avatar
The two ignition wires should be together to run.
I cant remember if that machine has a wet or dry stator, sorry... old age kicking in.
Old Sep 10, 2007 | 04:49 PM
Dan250race's Avatar
it is a wet stator, you are fine. That setup is better IMHO.
As for the kill switch. You got a 50/50 chance [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 10, 2007 | 05:59 PM
tdye's Avatar
Thank for the input guys. Glad to hear it is supposed to have oil there, scared me for a little bit.
Old Oct 23, 2007 | 11:47 AM
spent21's Avatar
yes, the stator is wet, but on the 250x, i believe the ignition is normaly open. i'll have to check my wiring diagrams, but if i remember correctly, i just unplugged my ignition/kill switch and the bike ran fine.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
