connecting rod
Old Sep 11, 2007 | 03:41 PM
a_diehard_pats_fan2000's Avatar
Default connecting rod
was wondering if its really hard to change a connecting rod in myn foreman...it looks pretty simple..and is it pressed on the crank by a pin
Old Sep 11, 2007 | 03:48 PM
quicksilver's Avatar
yes, the crank assembly is pressed together, there is no connecting rod 'cap' like automobiles have. you'll have to remove the engine, split the case and remove the crankshaft assembly and bring it and the new rod/bearing kit to a small engine or powersports shop with the right equipment and have it done. make sure you have someone check the length of the new rod compared to the old one to make sure they are the same... i had a nasty hiccup with a 2-stroke 3 wheeler when i replaced the connecting rod with one that was 1/4 inch shorter.
Old Sep 11, 2007 | 04:06 PM
thank you....so do i have to split it all apart or just the middle
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
