craptor reverse switch problem?
Old Sep 11, 2007 | 09:03 PM
bombrider04's Avatar
Default craptor reverse switch problem?
I was wondering if someone could tell me how to either bypass the system or disable it so the carbs on the 660 raptor won't conk out on wot...thanks
Old Sep 12, 2007 | 11:30 AM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Good question Im wondering the same thing, we just check the conection and fix it all the time but a bupass would be nice
Old Sep 12, 2007 | 06:20 PM
Well the problem was 2 things mixed into one the one carb wasn't getting any gas so I fixed that and now when I have the throttle held in and at wot it will start conking out and sounds like it is hitting the rev limiter for reverse, but the reverse light has only come on a few times...I checked the connection at the right angle where the sensor goes into the tranny and it seems to be clean, but I don't know what to do from there I guess check to see if there is any loose wire or I dunno.
Old Sep 12, 2007 | 09:58 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
If it has an E-BRAKE check that switch.........
Remember the rev limiter is at 8500 on the OEM cdi
Is your question about the reverse rev limiter or the rev limiter in general??????
txkevin
Sep 21, 2015 02:02 PM
Bigredjeep
Jun 22, 2015 11:30 AM
scaldwellk
Jun 19, 2015 05:08 PM
kodiak450.
Jun 17, 2015 02:22 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
