Tighten Chain
Old Sep 15, 2007 | 06:10 PM
LJ68's Avatar
Default Tighten Chain
Hi
How do you tighten chain on a Polaris 1999 Xplorer 400.I have a suzuki 400z, that is pretty easy to adjust,but this polaris I do not have a clue talked to a few shops one wanted me to bring it in so they could do it and then show me of course for a charge.And another wouldnt let me talk to a mechanic insted suggested I by one of there service books.Well call me cheap if anyone could help me with this it would be greatly appreciated.
Thank you
Old Sep 16, 2007 | 04:25 AM
dosceola's Avatar
I would think its in sprockets,or rear wheel setback. only way i know to tighten chain on anything
Old Sep 16, 2007 | 10:08 AM
embler's Avatar
let's see if I can explain how to tighten it up. at the rear axle, there are 2 bolts that look like they clamp down onto the mid section, loosen those up. looking at it from the rear, there's a bolt on the bottom side (again at the mid section) on the left side, loosen it up also. after you loosen them up, use a wrench (channel locks or pipe wrench works) and on the mid section turn it away from the bike. its a bear to turn sometimes. you'll see the chain tighten up when you turn it. hope this helps.
Old Sep 16, 2007 | 11:15 AM
LJ68's Avatar
Thanks for the feed back, I will try this,and let you know how it goes, I do not have the atv at home right know,when I get I will try this.
Thanks again
Old Sep 16, 2007 | 07:49 PM
Wenty's Avatar
First off compress the rear suspension till the bike is level, I use a ratchet strap from the bumper to the axle
Exact words in my 98 explorer book...
1. Loosen chain gaurd
2. Loosen two eccentric locking bolts,(these are the bolts embler spoke of)
3. Insert a pin punch through the sprocket hub and into the eccentric axle housing, (this is on the right side when looking at the bike from the rear)
4. Roll the vehicle ahead or back to adjust chain slack to the proper dimension, 1/4"-1/2".(It can take a pretty sharp push to loosen the bond between the clamps and hub)
5. Tighten the eccentric locking bolts to 60ftlbs
6. reinstall chain gaurd
P.S. If you go to Polaris.com you can download the owners manual, it'll help explain with the diagrams.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
