Honda TRX300 only runs on choke
Old Sep 17, 2007 | 11:58 AM
Greencanyon1's Avatar
Default Honda TRX300 only runs on choke
Working on a 1994 TRX 300 2wd. This is the first ATV I have worked on so I need some help.
THe engine runs good on full choke. Take it off choke and immediately kills.
Has been sitting up for a while so we put new gas, oil, spark plug, air filter.
Could the gap on the plug be the problem?
I "cleaned" the carb as best I could. seems to be very very little varnish. I removed the jets and one of them looked clogged. I tried opening it with a metal rod and couldn't push it through. Has 4 spall holes running through the sides, but the inside tube is closed. Should this be open? It feels like metal inside, as if it is supposed to be closed.
Could it be the choke needle cutting off fuel flow?
I tried the idle at a few positions and had same result.
Thanks for the help.
Old Oct 25, 2007 | 10:01 PM
fbody93's Avatar
I'm having the exact problem on a 93 300, i'd like in on this post too if anyone has any ideas.
GregM
Old Oct 25, 2007 | 10:40 PM
MadRebel's Avatar
Anytime an engine has been sitting up for a long time you can pretty much bet that the slow speed (idle) jet is cloged. It needs to be disassembled, soaked in carb cleaner, blown out and reassembled. hope you didn't damage the jet by pushing the rod thru it.
Old Oct 25, 2007 | 10:48 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Classic clogged idle jet. I have two quads with the same problem right now, from sitting all summer (spring, fall, and winter are the riding seasons here...summer is way to hot to ride desert).
One other possibility is a leak in the air intake system (it is getting to much air, so cutting it down with the choke makes the difference).
Old Oct 26, 2007 | 10:12 AM
RedRubi's Avatar
Ways to prevent this problem is use Fuel Stabilizer or simply start the machine once in a while to get fresh fuel into it.
Old Oct 26, 2007 | 10:21 AM
MadRebel's Avatar
Exactly, the best thing you can do for an engine is to run it, and run it often!
Old Oct 26, 2007 | 12:02 PM
Red Rider
Fuel stabilizers are moderately effective, at best! I speak from experience here!
Old Oct 26, 2007 | 04:52 PM
trx300man's Avatar
Definitly a clogged jet, take it back apart, take a single wire from a wire brush or wire wheel and push it through the jet. I have done it many many times.
Old Oct 28, 2007 | 10:19 PM
kgcool's Avatar
go to your local auto parts store get a can of carb soke, it comes in a one gallon can. Disassemble your carb, and let it soke for 45 mins. wash off with carb cleaner and reassemble. just make sure you dont put rubber parts in the soke because it will eat them. Also use wire in various size to clean out the purge holes in the jets.
Old Oct 28, 2007 | 10:23 PM
kgcool's Avatar
the carb soke will get any and all varnish out of the carb and jets. dont leave it in for more than 45mins because it can start to eat away at the aluminum after a whil
chinkapin
Jul 14, 2016 06:58 AM
Big600twin
Jun 10, 2015 03:01 PM
jayking232003
Jun 9, 2015 02:54 PM
hunterman
Aug 11, 2000 09:03 AM
lovinhonda
Jan 25, 2000 09:17 PM
