smoking grizzly
Old Jan 4, 2001 | 03:41 PM
grizz00's Avatar
I have a oo grizzly that smokes on cold startups after a oil change so the dealer changed oil filter still smoked then thay did a compression test checked valves changed plug serviced air cleaner still smokes it only has 100 miles on it help
Old Jan 4, 2001 | 03:45 PM
quadcrazy's Avatar
Did your dealer check the valve seals.
Could be a problem there. How bad is it? Is it white smoke?
Old Jan 4, 2001 | 04:59 PM
grizz00's Avatar
the smoke blue thay did leakdown test to it only smokes after siting overnight
Old Jan 4, 2001 | 07:00 PM
therock's Avatar
Hmmm? I am thinking Valve seals or guides too. Other than that I am hearing of Differential vents pushing oil into the air box. Maybe it settles into the carb boot or the Filter is soaked?
Good Luck.
Old Jan 5, 2001 | 12:02 AM
grizz00's Avatar
air filter is clean
Old Jan 5, 2001 | 12:44 PM
NEPHI's Avatar
DOCUMENT ALL CORRESPONDENCE WITH YOUR RETAILER IN CASE THE PROBLEM BECOMES WORSE. A NEW MACHINE SHOULDNT CAUSE THIS KIND OF STRESS YOU HAVE A 6 MONTH WARRANTY AND SMOKING IS NOT RIGHT TELL THEM TO FIX OR REPLACE TO YOUR SATISFACTION. I OWN A 01 GRIZ NO SMOKE. JUST A THOUGHT, WHAT OIL ARE YOU RUNNING ? HAVE YOU EVER ROLLED IT ? GOOD LUCK FELLOW GRIZZER !!!*!
Old Jan 5, 2001 | 12:48 PM
ERICsRAPTOR's Avatar
Tell the grizzly that smoking is bad for it's health. At least you can replace the lungs in these.
LOL
Old Jan 5, 2001 | 05:24 PM
grizz00's Avatar
it never been rolled the oil I use is yamalube 20w-40
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
bvolks
Sep 13, 2015 12:57 PM
