Help on brakes that lock up
Old Sep 20, 2007 | 08:09 PM
MWells's Avatar
Default Help on brakes that lock up
Hi, I have an 1988 Polaris Trail Boss that I'm trying to keep running, but the problem is that the brakes are locking up. The brake lever is very hard to squeeze even if the brakes aren't locked up. We have replaced the rear pads and bled the rear brake. I have been able to bleed 1 of the 2 front brakes, but the bleader has been broken off one of them flush. One thing that we noticed was that when the machine warms up, or has been sitting in a shed when it is hot the brake will lock up.
Any ideas or suggestions would be appreciated... Thanks
Old Sep 21, 2007 | 02:55 AM
dosceola's Avatar
Your cables might be bad that would explain hand break issue. Have u replaced fluid? dont worry about bleeding all but one caliper.it should not be a problem. I would think new calipers would fix it. Piston inside is getting stuck when out all the way. Is it mounted correctly? also check Rubber on master cylinder on handlebar and piston boot on calipers
Old Sep 21, 2007 | 03:36 AM
ozarkhunter's Avatar
I had a similar problem with my 88 trail boss. The rear brake would apply preassure but was very slow to release and this would stop you where ever you were. The pads would be smoking. I finaly took mine to a guy who works on them and he flushed the lines and put new fluid in them. They had alot of sludge in them. On mine there is no cables.
Old Sep 21, 2007 | 07:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
either the master cylinder, or the caliper is messing up. find which wheel is locking up and see if the caliper piston is sticking out and not releasing to go back in.
Old Sep 21, 2007 | 10:18 PM
MWells's Avatar
Thanks for the suggestions, I'll try them out this weekend.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
