Polaris Ranger Fires
Old Sep 21, 2007 | 12:25 PM
firelaw's Avatar
Default Polaris Ranger Fires
I know of a 2007 Polaris Ranger 700 with only 40 hours use which caught fire. Fire orignated in front of vehicle, probably in electrical wiring. Please advise if you know of similar fires.
Old Sep 21, 2007 | 10:35 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Not on any 2007.............Re-call on ECM back in 2004/2005...........Do to the risk of fire.............................................. Just a side note here..........My Electrical fa for cooling the RAD came on without the key in and ran ALL NIGHT........Killed the Battery.............this is on a 2006 Sportsman 450...............Already put a second Sure Power Black Box in ...........Now I looking for a Third one.........................Scarry stuff............This controls "ALOT" of stuff on the Quad!!!!............Caper..........
Did they find a cause for the fire yet!!.............
Old Sep 21, 2007 | 11:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
could have been a bad short in the wiring as well that caused it.
Old Jan 10, 2008 | 12:50 PM
firelaw's Avatar
Sorry for the delay. We just got the engineering report back, that based on the short usage time, about 40 hours, and the lack of improper maintenance, modification or other damage, fire probably resulted from some defective electrical component.
Old Feb 18, 2009 | 10:24 PM
bawb450r's Avatar
I just found this post from a search and thought I would add my piece.
To make a long story short I found the main power wire from battery to starter shorting against oil fill tube and arching every time vehicle was started.
Here is my horror story with the 07 700 XP. Motor mount/ Belt/ Clutch problems.
http://www.prcforum.com/viewto...postorder=asc&start=45
Old Jan 28, 2013 | 01:10 PM
imgilly's Avatar
Default firelaw - contact
Firelaw - can you please contact me via email bgilbert@dgalaw.com thank you.
Old Jan 28, 2013 | 02:07 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
so-
how'd that first law suit work out fer-ya?
just wondering... you take "exploding tire" cases?
Old Jan 28, 2013 | 02:16 PM
scootergptx's Avatar
Supersock
Hired Gun!
Careful, you don't want to be sued by some of the tires you've owned.
Old Jan 28, 2013 | 02:21 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
jeeeez-
none of my tires have any disclaimer saying there could be an explosion if I used a torch to remove a stubborn bead that also had a flammable tire sealer in it! it's THEIR fault!
Old Jan 28, 2013 | 03:20 PM
Heard through the grapevine that the regulator/rectifiers would heat up,but didn't have any show up at the shop. Think this was only on a few early units in 2007. The module did change after January build dates. OPT
