What are the symptons of a need to rebuild?
Old Sep 24, 2007 | 11:30 AM
springdrl's Avatar
Default What are the symptons of a need to rebuild?
I have a '92 Fourtrax that I puchased used about six years ago and need advice on what to look for that indicates it's time to rebuild the engine. It's always seemed to have a slight knock whenever the engine is under load (such as going up hills or in deep sand), however it doesn't burn a drop of oil. I know it's been a while since I adjusted the valves, however the knock doesn't sound anything like the ticking sound of loose valves. I've been thinking it might be rod knock but not certain. It doesn't get driven very hard or often since I use mostly during deer season in the Fall.
All comments and suggestions are appreciated?
Dan
Old Sep 24, 2007 | 03:22 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
I have the same knock on my 400EX. It was much more pronounced until I started running 91 octane. I was told here on this site that it is normal.
Old Sep 25, 2007 | 01:39 AM
springdrl's Avatar
Thanks for the reply.
I checked with a friend who rides dirt bikes professionally and he said the same thing about Hondas being a little noisy once they get some hours on them. I'll also start using higher octane gas and adjust the valves and see what happens.
Thanks again.
Old Sep 26, 2007 | 07:30 PM
JeffinTD's Avatar
Yeah, Rincons can make a klack kind of noise which seems to be normal, too.
If yours makes noise only when you are on the throttle hard, especially at lower RPM, that would be the classic description of pre-ignition/detonation, IE needs higher octane fuel...
You said that it's had the slight knock for the 6 years that you've had it... If it were a rod, I'd expect it would have gotten worse (or more likely blown up by now).
Old Sep 27, 2007 | 04:56 PM
quicksilver's Avatar
my 2004 and my 2005 rancher make a decent clinky noise at idle, so i think the notion that the honda's get a little noisy when they have some hours on them is pretty accurate.
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
