Toe in or toe out of rear wheel 700 Sportsman
Old Sep 25, 2007 | 01:42 PM
GAT's Avatar
GAT
Default Toe in or toe out of rear wheel 700 Sportsman
I have an 04 Sportsman 1200 miles. I notice that one of the rear wheels has a noticable toe to it...out at the top in at the bottom. Bushings are new bearings are new...doesn't drive any different nor do I really notice it unless looking for it. Is this fairly normal???
Gat
Old Sep 25, 2007 | 04:51 PM
outside2day's Avatar
Doesn't sound right. Would think something is bent or broke, but you say new bearings and bushings? My guess was going to be an A arm bolt broke. Need to look it over real good, maybe jack it up, and tug on that tire, see if anything is bent or broken. Good luck.
Old Sep 25, 2007 | 07:44 PM
SCRAMMYTODD's Avatar
Ya if it's differant side to side something is probably wrong. And just for correction if it's out at the top and in at the bottom, it's a camber problem, not a toe problem
Old Sep 25, 2007 | 09:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it was the other way i would say that maybe the shock or spring is bad but if its pushing the top of the tire out then i would agree maybe something bent or really off from the other side.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
