2002 warrior needs help
Old Sep 26, 2007 | 10:09 PM
MUDPUP4X4's Avatar
Default 2002 warrior needs help
i just got it (dirt cheap)so i don't know much about it but it backfires out the carb at an idle and low rpms i noticed the the carb boot was split so i replaced it and it still does it. I also checked cam timing its ok, checked intake valve it had about .006 clearance at TDC.
Old Sep 26, 2007 | 10:26 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
.006 mm or inches? also, did you check the exhaust side?
Old Sep 27, 2007 | 06:15 PM
STRAIGHTUPDAHILL's Avatar
check for loose plug...bad accel pump...(if the rod is even in it)..the one i just bought was missing..lol
or jet blockage
if it has a aftermarket adjustable exhause...take some discs out...to create more backpressure
Old Sep 27, 2007 | 06:16 PM
how dirt cheap was it?
Old Sep 28, 2007 | 07:37 PM
Jasonp's Avatar
should have around .003" intake and .005" exhaust.
Poping or backfiring out of the carb is a lean condtion.. pilot circuit or fuel screw on the bottom of the carb is pluged or has to be adjusted.
Old Sep 28, 2007 | 07:51 PM
MAKE SURE THE BATTERY IS FULLY CHARGED TOO....
Old Sep 28, 2007 | 08:40 PM
MUDPUP4X4's Avatar
It turned out to be the pilot screw i turned it all the way in and the back out 2 complete turns and it runs great. Thanks alot for your help.
Old Sep 28, 2007 | 08:41 PM
Jasonp's Avatar
money! sweeet.
95wolv
Sep 27, 2024 12:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
byronman
Sep 6, 2015 06:34 PM
