Scrambler 400 and secondary help
Old Sep 27, 2007 | 10:36 PM
Maddog419's Avatar
Default Scrambler 400 and secondary help
Hi all: I have a scrambler 400 yr 1999 that I'm trying into a polaris hybred. Using a polaris 440 yr2005 motor in it.
I was told to open the driven clucth out all the way. Not sure what this realy means can it become wider from the spring
settings. 1-1 or 2-2 ect, not sure any help would be greatfull. No shims maybe ???
Thanks
Old Sep 27, 2007 | 11:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im not sure what they mean either as the changing the spring setting just changes the spring pressure and has nothing to do w/ clutch width while its closed and shimming between the sheeves will opened it a little to allow the belt to drop down some. why would want that is beyond me??
Old Sep 28, 2007 | 11:01 PM
Maddog419's Avatar
Thanks stendori:
My take on it might be that you need to open up the driven side to get the belt from the wider snowmachine primary side.
And use the snowmachine drive belt, anyone help, thoughts???
Old Sep 28, 2007 | 11:32 PM
SCRAMMYTODD's Avatar
Well if you get it to work correctly, it should FLY!!!! Let us know how it works
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
