Ok, i give up how do I tighten...
I've stared at that rear end long enough and it's killing me. I see the tensionner ring just inside of the sprocket that moves the axle back but can't figure out what needs to be loosed to give it enough play to move. Any ideas?
At the very back of the bearing casing on the bottom are two hex bolts, i'm about to go loosen those and see what happens, then there is also the big nut that looks to hold the right rear axle on...? arghhh.. months in the making finally 90% and i can't get the chain tight enough!!!!!!
HELP!
Jay
HELP!
Jay
Ok, i figured it out, it was the two pinch bolts at the back of the bearing housing. Man, i can finally tear it up a little! I'm off to get muddy!!!
Have a great weekend all!
J
J
Sep 30, 2015 01:37 AM
