Battery light flashing 05 800 sportsman
Old Sep 29, 2007 | 12:53 AM
schmidthead74's Avatar
Default Battery light flashing 05 800 sportsman
I have the battery light flashing on the 800. At first i thought it was the battery, so i put a new one in. Plus the tach stopped working...... Didn't help
Next i tried a new voltage regulator.
Now the the battery light flashed still. And the tach counts down from 400 to 10 then goes to 5000 then to 3100.
What are your thoughts on my problem?
I have seen people talking about stators and ecu or ecm. Are these an issue?
Old Sep 29, 2007 | 01:07 AM
UTU's Avatar
UTU
Are you using winch,3 way headlight mod or any other non stock electrical accesories? Sounds like stator not putting out enuf?
Old Sep 29, 2007 | 07:11 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you having anyother problems w/ it for electrical. is it flashing all the time or just when idling? did you check the voltage output when running. i dont think tact(guessing) would have that reaction w/ no current w/out shutting the bike off from less then 12 volts it takes to run it. it may have a bad emc or going bad. that thing controlls about have the bike i think. just a thought.
Old Sep 29, 2007 | 01:11 PM
The light does not flash all of the time. Sume times under power and other time when idleing. If im running 40 mph the light will flash for 2 miles the shut off then come back on it 2 more miles.
Also what is an emc? My dealer does not see one on the computer.
Old Sep 30, 2007 | 06:25 AM
THECRAIGMEISTER's Avatar
My 07 800 was doing the same thing at random times so I took it in. Only has 240 miles on it and always starts but was worried since it doesn't have a pull start. The mechanic thought it would be the battery but it turned out to be something in the charging system. I think he said it was the PDM?
Old Sep 30, 2007 | 03:15 PM
well i have tried a different ecm and speedo pod. I also checked the plug wires for a short. i still can not find the issue.
Any other thoughts?
Old Sep 30, 2007 | 03:56 PM
I am supposed to get mine back early next week. I will let you know. You may have to take it to the dealer and have them check the charging system, voltage regulators etc.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
