1984 TRX200 Woes
Old Sep 30, 2007 | 01:12 PM
jhrobert's Avatar
Default 1984 TRX200 Woes
I recently bought a 1984 TRX200 to fool around with. The coil only fires once when you try to start it. This happens either with the starter button or using the pull start. I did check the magnetic rotor pickup on the side of the camshaft. It does turn when you try to start the motor. You need to turn off the key each time in order for the one spark to work. Trying a second time without turning off the key will produce nothing. Help. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 30, 2007 | 10:47 PM
atcer200x's Avatar
not sure but sounds like something isn't grounded. If you haven't done so, try disconnecting then reconnecting all the ignition wiring.
Old Oct 1, 2007 | 12:28 AM
jhrobert's Avatar
Thanks, that sounds like a good place to start. I did try the coil wires today and it was doing the same thing. I'll try and check the wiring sometime this week and see what happens. I'll have to pull the front fenders and gas tank to get at the wiring.
Old Oct 1, 2007 | 07:14 AM
HondaMechanic's Avatar
PM your email adress if you want/need the ignition section of the 1984 TRX200 PDF shop manual to test
Old Oct 5, 2007 | 12:40 AM
jhrobert's Avatar
The problems have been found. There is a ground wire under the front fenders near the steering column that was loose. Once I fixed that I was getting some spark. The spark plug was also no good. A new plug cured that problem. The ATV runs pretty good now. I just need to set the carb on it so that it will saty running. The idle is too low. Thanks Honda Mechanic for the test info.
Old Feb 17, 2008 | 09:31 PM
Furmac's Avatar
hi Im a new owner of a old 1884 trx200 & need all the help i can get on this trx200
are you still offering a 1984 TRX200 PDF shop manual any sections or any thing you can offer will help me alot
(I need all the help i can get thats what the wife says:-) )
Thanks for your time & if you can't help with the manual thats ok
Thanks
Dana
Nova Scotia
P.S.
My e-mail is furmac@eastlink.ca
salixair
Nov 3, 2015 08:25 AM
timster911
Jul 13, 2015 01:57 PM
rabnud
Oct 17, 2002 08:11 AM
rabnud
Oct 29, 2001 10:28 PM
Peltrax
Sep 10, 2000 10:56 AM
