'99 trailblazer
Old Oct 3, 2007 | 09:40 PM
xljimmy's Avatar
Default '99 trailblazer
I just purchased a '99 trailbazer and it is alittle worn out, lol. When searching for parts I keep coming up with gen I.II.III. I am guessing they are a year identified in a surious change or makeover. What are the years they stand for? Is it just trailblazer or is that for all models of polaris atv?
Thanks
Old Oct 3, 2007 | 11:17 PM
xljimmy's Avatar
Also someone put scrambler front fenders on it. What else is same on the trailblazer as the scrambler? rear fenders? seat? airbox?
The oil injection is unhooked and there is no oil line. Is that just an ordinary line or something special. Someone said something about it being special so it dont collapes and restrict oil. Anybody know anything on that?
Thanks
Old Oct 4, 2007 | 12:17 AM
Blacksheep5's Avatar
the fenders are the same, everything is the same except the drive train you have a gen 3 my 2000 trailblazer is a gen 3 too
i dont know about special line for the oil line, i just used clear fuel line and i have had no problems, just make sure you do not run it with out the oil line hooked up or a pre mix of fuel and oil.
you also have to purge the oil pump if the line has been taken off
Old Oct 4, 2007 | 12:19 AM
also when your looking for body or chassis parts you can use parts from a 3rd gen Scrambler, Sport or Trailblazer
airbox is different then other bikes, you can find alot of parts on ebay
Old Oct 4, 2007 | 08:54 PM
xljimmy's Avatar
wow thanks blacksheep5, exactly what I needed to know.
What about engine parts are they same as trailboss 250?
What years is the 3rd gen?
Old Oct 4, 2007 | 09:11 PM
xljimmy's Avatar
clutch covers? what are the same models there, lol. Sorry for all the questions. But the more models I can hunt down the more options i can get on ebay. This needs about everything but whole drive setup, steering and shocks. The brakes suck, wheel bearing bad, axle carrier bearings bad, clutch cover duct taped hole, front fenders is ok but not pretty but rear is not ok................................................ ...........
How do you purge the oil pump. When I get it hooked up I figured I would just run it with the premix still untile its super smoking to know its working.
Old Oct 5, 2007 | 01:35 AM
the Polaris 250 2-stroke is the same on all bikes I think
i know that body and chassis parts fit from 96-07
clutch covers should be the same from all years of trailblazer, scrambler and sport and maybe trailboss
I think the trailboss is the same except for body wise
i will have to look in my repair manual for the oil pump purging
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
