2001 325 trailboss help
Old Oct 3, 2007 | 11:22 PM
SherpaT350's Avatar
Default 2001 325 trailboss help
what compression reading should I have on this atv for min. ? I had an oil cooler line break and it ran out of oil. I replaced the line but it won't hardly run since.
Any ideas andf what is min. compression ?
Thanks,
D.
Old Oct 3, 2007 | 11:44 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Most engines should have at least 100 lbs to run.........may run with 90 not too sure.......My comp tester I use for the sleds is showing RED on the guage at 90 lbs.....100 is min on my guage!!!........Caper...........
Old Oct 4, 2007 | 12:04 AM
94harley's Avatar
A cylinder leakage test is a WAY better test for four strokes, especially ones with an automatic compression release. I would say if it's running good and you break an oil line, and then it doesn't run good, you have engine problems. Is it knocking? Hopefully if there are engine troubles they are piston, cylinder related and not the connecting rod or crank. They get spendy. Did you checkl compression on it? What was the reading?
Old Oct 4, 2007 | 12:34 AM
SherpaT350's Avatar
around 85-90 lbs.
Old Oct 4, 2007 | 08:00 AM
ftwflh's Avatar
Sounds like you toasted the rings.When you do the topend you may want to tear the lower end down too.The 325s had weak rod bearings and starving them with a busted oil line couldnt have done them any good
Old Oct 4, 2007 | 09:31 AM
scootergptx's Avatar
Supersock
Hired Gun!
Be a good time to call Rick Ritter and talk to him about a 414 kit too. [img]i/expressions/face-icon-small-wink.gif[/img]
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
