backfire and afterfire..there is a differance
Old Oct 4, 2007 | 02:50 PM
STRAIGHTUPDAHILL's Avatar
Default backfire and afterfire..there is a differance
just so everyone knows what end your talking about...
For other meanings of the term see backfire.
A Back-fire or backfire is an explosion in the intake manifold, carburetor/throttle body or air cleaner of an internal combustion engine. Although an explosion in the engine's exhaust manifold or exhaust system, is often referred to as a backfire, it is actually an afterfire.
The term was derived from experiences with early unreliable guns which could literally blow up in a shooter's face. From this came the use of the word "backfire", as a verb to indicate something that produces an unintended, unexpected, and undesired result.
[edit] Explanation
The terms backfire and afterfire are specific and exclusive. An explosion in the exhaust system is never a backfire. The following information refers mostly to afterfiring. Perhaps a mechanic who has more intimate knowledge of the causes of backfiring & afterfiring can sort out which parts belong where.
Backfire in an automobile engine typically results from various malfunctions related to the air to fuel ratio. Usually, backfiring occurs in carbureted engines that are running lean where the air fuel mixture has insufficient fuel. ("Running lean" is typically a sign of mal-adjusted carburetors or fuel injection where there is not enough fuel for the amount of air). Afterfire occurs in engines that have an emission system malfunction (air injection system diverter valve), exhaust leak or unburnt fuel in an exhaust system in which the catalytic converter has been removed. When a driver shifts up and lets off the accelerator, the engine has a moment of running rich or with insufficient oxygen. This causes an incomplete burn which causes the fumes to explode in the exhaust system. The leak itself is the most dangerous aspect. Without it, the mixture would cool enough not to explode. A fuel injected engine may backfire if an intake leak is present (causing the engine to run lean), or a fuel injection component such as an air-flow sensor is defective.
Common causes of backfires are:
Timing - If car is distributor-less
Timing - If a two stroke engine is backfiring every other stroke.
Fuel pressure, fuel filter and pump - leaks and corrosion could cause lack of fuel during the fuel injection event.
Bad wiring in ignition - ..if car won't run for more than a few moments.
In older engines, backfiring may be considered normal. Backfire is rare in modern cars with fuel-injection and computer-controlled fuel mixtures.
Common causes of back fires in the intake manifold are bad spark timing, or incorrect (usually lean) fuel ratio.
When starting an engine, timing that is too advanced will fire the spark plug before the intake valve is closed. The flame front will travel back in to the intake manifold, igniting all of that air and fuel as well. The resulting explosion then travels out of the carburetor and air cleaner. A common air filter will allow the gases to escape, but will block the flame front. On many small marine engines, no air filter is used, but a screen is placed over the intake of the carburetor as a flame arrestor to prevent these flames from escaping the intake, and potentially igniting fuel, or fuel vapors in the enclosed sump or bilge of the boat and causing a fire or explosion. Improperly adjusted carburetors that create a lean condition during acceleration can cause the air fuel mixture to burn so slowly, that combustion is still taking place during the exhaust stroke, and even when the intake valve opens. The flame front can then travel up the intake and cause a backfire.
In drag racing, backfires in the intake usually result in the complete destruction of the intake manifold, the carburetors, blower, and sometimes engine.
Old Oct 4, 2007 | 06:41 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
and then?
Old Oct 4, 2007 | 07:22 PM
AND THEN YOU GET OUT YOUR WALLET
Old Oct 4, 2007 | 07:23 PM
Jasonp's Avatar
and what web page did you copy that from?
Old Oct 5, 2007 | 01:37 AM
Wikipedia
saved me alot of typing
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
fordfaithful21
Dec 7, 2015 05:52 PM
fredrikrosen
Sep 28, 2015 09:58 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
