Warrior valve settings
Old Oct 6, 2007 | 02:00 AM
bigmike007's Avatar
Default Warrior valve settings
I have a 1997 warrior that i got in 03 and i have never checked the valve settings on it. I know how to check them, but i am unsure of what the clearance is suppose to be. I know they have to be off i can hear them ticking while it runs. Also i was wandering if any of you had an idea if this is rings or valve guide seals....or both, on start-up it will smoke a little til it gets warm then when i floor it it will send out a puff of blue smoke. Any help would be appreciated.
Old Oct 6, 2007 | 02:37 AM
STRAIGHTUPDAHILL's Avatar
DO A COMPRESSION CHECK
Old Oct 6, 2007 | 02:56 PM
Xtreme26181's Avatar
blue smoke sounds like valves, compression shld be 9.2 i think lol
valves for sure are:
Valve,valve seat, valve guide:
Valve clearance [cold]
IN. 0.06~0.10mm
[0.00236~0.00394in]
EX. 0.16~0.20mm
[0.00630~0.00787in]
________________________________________
If your unsure check this site..
http://www.sandwizards.com/Service_Manuals/warrior.pdf
Old Oct 6, 2007 | 03:01 PM
Raptor450's Avatar
Mine used to smoke like that. I replaced the valve seals, it helped but still smoked and did not stop smoking until I rebuilt the top end with a new piston and rings.
Old Oct 7, 2007 | 01:02 AM
bigmike007's Avatar
Thanks a million guys. Just curious how hard is it to replace the valve guide seals, I have done chevy small blocks tons of times. Is it the same concept. And how far can you bore out a warrior.....safely.
Old Oct 7, 2007 | 02:08 AM
Jasonp's Avatar
You can bore out a warrior up to .080"
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
