325 magnum bogs
Old Oct 9, 2007 | 11:33 AM
trybaj17's Avatar
Default 325 magnum bogs
i was riding down in southern illinois this past weekend and i noticed when i went threw a mud/ water hole it would bog when i gave it full throttle. this also happend when i was driving on the trails and,i let it warm up for 10 min. and it bogged when i went to give it full throttle, i was giving a family member a ride the whole week b/cthey dont have a quad. why is it doing this?
Old Oct 9, 2007 | 01:01 PM
deanz400's Avatar
need more info ,but in generel sounds like wires shorting out ,
Old Oct 9, 2007 | 01:47 PM
trybaj17's Avatar
it seemed like from 3/4 to full throttle it would loose powertehn about 5 or 10 minutes later it would run fine. it kept doing this for the whole weekend. it seemed like it had no power for the time when it acted up at 3/4 to full throttle. then other times it had all the power it usually has.
Old Oct 9, 2007 | 03:56 PM
deanz400's Avatar
did the engine actually bog or maybe the belt slipped ?
Old Oct 9, 2007 | 06:06 PM
trybaj17's Avatar
no the engine did not rev up like the belt was slipping. it boged down. i also noticed a smell. i cant explain the smell.
Old Oct 9, 2007 | 10:25 PM
ftwflh's Avatar
Check the belt and the secondary clutch buttons
Old Oct 10, 2007 | 12:08 AM
trybaj17's Avatar
would that make the engine bog down? how? why?
Old Oct 10, 2007 | 07:57 AM
ftwflh's Avatar
yes it can cause a bog if the secondary inst working right it can load the engine up.
Old Oct 10, 2007 | 09:30 AM
deanz400's Avatar
if the clutch is n't shifting right ,like not backing down then it would be trying to pull amuch higher gear thus bogging the engine down ,
pull the cover off and blow all the belt dust out of the clutch area .
Old Oct 10, 2007 | 05:25 PM
trybaj17's Avatar
Im at school right now, the next time i will be able to ride my quad is in about three weeks. Im thinking of changing the clutch springs in the summer to an EPI primary, and a aaen blue secondary. Will it hurt the quad if i wait till then to check the secondary buttons?? Should i replace the belt? i think its the orginal from 2002? what should i look for with the secondary buttons?? what does the helix do in the PVT??
Gwolf228
Feb 18, 2017 01:36 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
