2004 700 efi fule pump (sending unit)
Old Oct 9, 2007 | 03:58 PM
NEK VT's Avatar
Default 2004 700 efi fule pump (sending unit)
How many of you with a 2004 700 efi had fule pump problems? please give me a description as i want to compare this to my problems.... also can I gat a cheap aftermarket pump that will work?
Old Oct 9, 2007 | 09:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you do asearch you'll see where i found an airteck and another guy crosses it to a napa pn#. most people who have had trouble is when it starts to heat up and it completely breaks down and wont even start. another problem is they had problems w/ the internal wiring. they changed pumps in 07/23/07 ( ithink thats the date) on the 800's and guessing the same goes for the 700's. i dont know but im guessing its not the fuel pump thats giving the problem but i could be wrong.
Old Oct 9, 2007 | 09:15 PM
94harley's Avatar
Is your problem with the pump itself or the fuel level sending unit? If it's the sending unit I bet you will have to get that through Polaris. If it's the pump there is a thread about it like stendori said. What exactly is wrong with your machine?
Old Oct 9, 2007 | 09:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
harley, read his other post ( polaris gures help) yea i spelled it wrong too lol.
Old Oct 10, 2007 | 12:04 AM
NEK VT's Avatar
YEAH i CAN'T SPELL, LOL no I am not sure if it is a pump or sending unit problem, or somthing else... I saw those p/n's for napa today but I thoutgt that was for an 800, also , do i really need a whole tank assembly if it is the pump, .... usually you can swap sending units and pumps out of most atv's and cars easy... I havent done much work to this machien yet because i just got it and this is the first problem.
Old Oct 10, 2007 | 09:06 AM
js73751's Avatar
I thought the 2005 800 was the first with EFI. I do not believe the 2004 700 was fuel injected (my buddy has one). The fuel injected quads have the pump in the gas tank. Where is yours?
Old Oct 10, 2007 | 10:07 AM
NEK VT's Avatar
in 04 they made a carberated 700 twin and they made a 700 twin EFI.
Old Oct 10, 2007 | 10:08 AM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: js73751
I thought the 2005 800 was the first with EFI. I do not believe the 2004 700 was fuel injected (my buddy has one). The fuel injected quads have the pump in the gas tank. Where is yours?</end quote></div>
Models A04CH68AP/AQ/AU/CU are fuel injected according to the parts lookup on Polaris' webpage so there are 04 700 fuelies.
Old Oct 10, 2007 | 11:37 AM
js73751's Avatar
Thanks for the correction.
I will be posting additional part numbers for the 800efi pump which is also available from Carter Pumps for under $100 including a new filter screen.
Joe
Old Oct 10, 2007 | 11:42 AM
NEK VT's Avatar
do u know what they are for the 700?
