2004 700 efi fule pump (sending unit)
Old Nov 12, 2007 | 08:26 PM
  #21
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 2004 700 efi fule pump (sending unit)
the airtec pump i mentioned in earlier post was information i got from other people who had used this as a replacement and do not have first hand experince in seeing it work myself.
Old Apr 10, 2008 | 04:55 PM
  #22
NEK VT's Avatar
well 94harley saved the day(he gave me a pump), I put that pump in last fall in my gararge, it was cold and below freezing. well when i put it all back together the shifter dident move so I said well it must be stuck between gears, ill start it and it should shift, well because of stupid safty fetures it never started and I thought i had eletricle problems. well the other day it was warm , and i was wondering if i had some water in the shift linkage box that frose so I tried moving the shifter. It shifter to park, I then tried it and the thing started right up. I then went for a ride and all was fine and dandy. It was the fule pump after all.
So Thanks 94harley the ATV is fixed!
Old Aug 21, 2008 | 07:29 PM
  #23
jp1's Avatar
jp1
Default 2004 700 efi fule pump (sending unit)"></title><script src=
hay I posted some stuff about 700 efi 04 fuel pump problems. read it . I hope it will help.
Old Aug 21, 2008 | 07:40 PM
  #24
jp1's Avatar
jp1
hay whats up . I found that if you put insulated high temp tape on the bottom of your tank , plus put some headder wrap from the head down about a foot. this should solve your problem. the cause is that ths exhaust pipe is to close to the bottom of the gas tank causeing the gas to get too hot . then the quad will vapor lock. hope this will help.
2many2ride
Sep 27, 2015 04:35 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
