scrambler rear axel
Old Oct 10, 2007 | 07:43 PM
badwelder's Avatar
Default scrambler rear axel
how do i get the big nuts loose on the axel is there a need to know way ty
Old Oct 10, 2007 | 08:06 PM
94harley's Avatar
What year is this machine. the info below may be for older machines. I need to verify first.
I believe they are a 1 and 3/4 inch nut. They also rust most of the time making them hard to remove. I have had them rusted so bad that I had to use an air hammer(the biggest one snap on makes) and remove them that way. Put the machine in gear. Have someone hold the brakes and try to break them free. Use penetrating oil. You may try heating them. Do what ever you have to, to get them off. They do get nasty at times. Good luck.
Old Oct 10, 2007 | 09:44 PM
badwelder's Avatar
ty for the info got it off
Old Oct 11, 2007 | 07:11 PM
ftwflh's Avatar
I dont mess with fighting the nuts!I get a drimmel out with a cutting wheel,make 2 cut in the nut stopping before the threads and finish splitting it with a hammer and chisel.It save time and cussing to replace the nuts.they are only around $10
Old Oct 11, 2007 | 09:30 PM
la90043's Avatar
that axle nut is a 1 1/8.....................................
STLyamwar
Jul 25, 2020 04:44 AM
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
maxjung
Jul 13, 2015 05:11 PM
