400ex choke problems
Old Oct 11, 2007 | 11:01 PM
dabrowat's Avatar
Default 400ex choke problems
My 03 400ex has a problem. When I add gas with the choke on, its good. But when I turn the choke off, I will try to add gas and it dies. What can the problem be?? Thanks for your help.
Old Oct 12, 2007 | 12:32 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A lot of these "it won't run without the choke on" posts lately......
You are getting to much air for the amount of fuel. Most likealy a clogged jet, but could also be an air leak. Check the air filter, and the boot between the airbox and the carb for leaks. (Remove the air filter, hold your hand over the opening and crank the engine a couple of times. It should suck on your hand and not lose vacume readily if there isn't a leak.)
Old Oct 12, 2007 | 09:38 PM
Quad-Maniac's Avatar
Must be a lot of bikes just coming out of mothballs, after the summer off (at least here in So Cal.)
Likely clogged jet or sticky float valve.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
95wolv
Jul 21, 2015 12:25 PM
ghost civic
Jul 20, 2015 12:36 PM
yambam13
Jul 4, 2015 01:49 PM
