Shifting question.
Old Oct 12, 2007 | 09:11 PM
W4rri0r2000's Avatar
Default Shifting question.
Well I just recently got my warrior and it is the first time I'm ever shifting, but I've got the shifting concept down and everything, but I have one problem and it's taking off from neutral. I don't get it, I was watching youtube videos and people take off from just standing real quick, but when I do it, I slowly release the clutch as I slowly push the throttle and then I'm off. Before when I didn't get it, I would just drop the clutch and the quad would jump up a bit, but then I got it, but I still take off very slowly. Am I doing something wrong? Can I take off faster in any way?
Old Oct 12, 2007 | 09:16 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
just practice taking off, you'll get the hang of it... and they aren't starting from neutral.. they pull in the clutch in 1st gear and then launch..
Old Oct 12, 2007 | 09:24 PM
Yeah I know that's what I meant. I guess after a while I will figure out just how slow I have to drop the clutch and stuff, I guess.
STRAIGHTUPDAHILL's Avatar
they are also burning up their clutch..oh the price of fun
Old Oct 12, 2007 | 09:45 PM
Quad-Maniac's Avatar
Trick is to increase pressure on the throttle as you let out the clutch, so the engine speed stays about the same. As you practice, you can do the same thing faster and faster, till your doin just what u see everybody else doing.
Old Oct 13, 2007 | 09:17 AM
Speedy2222's Avatar
you don't just drop the clutch.. that's something i learned when i was stunting.. it's all about fast engagment.. clutches are cheap anymore and really aren't that bad to change.
Old Oct 13, 2007 | 12:27 PM
warpigs's Avatar
Yeah just practice it takes some getting used to if it's your first time. One thing I've noticed with warriors is if the clutch cable and perch is worn it makes learning harder as it is not smooth.
Old Oct 13, 2007 | 01:05 PM
Speedy2222's Avatar
^^ definitely, clutch cables are only $10 and very easy to replace.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
