02 yamaha raptor bogging
Old Oct 14, 2007 | 09:17 PM
mxz670HO's Avatar
Default 02 yamaha raptor bogging
My 02 yamaha raptor is starts up and idles but bogs,sputters and backfires when you give it gas.It was running okay but took a little time to warm up then it all of a sudden started bogging when you give it gas.It was running strong and fast.I have replaced the spark plug which looked okay and tested the wire and coil.It has a K&N filter but is otherwise stock.Do you think it is the carbs, ignition or valves? Thanks for your time.
Old Oct 14, 2007 | 09:20 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
parking brake.. check the parking brake.. then remove it
Old Oct 14, 2007 | 09:30 PM
mxz670HO's Avatar
Thanks for the quick response, can you tell me the the things i should check on the parking brake that would cause this?The dealer said the carbs are dirty and need to be cleaned or the needle is clooged or something like that.I have a clymer's manual for it.
Old Oct 14, 2007 | 09:31 PM
Speedy2222's Avatar
on the rear brake there is a "level" on the left side... press it forward.. see if that fixes it ..
Old Oct 14, 2007 | 09:33 PM
mxz670HO's Avatar
Also do you think the cab intake "boots" could be loose.I have the plastic off and havent really checked this but i heard this could cause this from other forums.
Old Oct 14, 2007 | 09:35 PM
Speedy2222's Avatar
try what i said first
Old Oct 14, 2007 | 09:40 PM
mxz670HO's Avatar
Thanks, I'll check that out.I heard that could cause problems.Where exactly is the level on the machine?
Old Oct 14, 2007 | 09:43 PM
Speedy2222's Avatar
lever.. it will look like a bicycle brake line going to it ...
Old Oct 14, 2007 | 09:50 PM
mxz670HO's Avatar
Is it on or next to the foot brake? because i thought that was the rear brake.
Old Oct 14, 2007 | 09:52 PM
Speedy2222's Avatar
it's on the rear brake caliper itself
