07 800 X2 dlx loud squealing noise
Old Oct 15, 2007 | 08:44 AM
Nix377's Avatar
Default 07 800 X2 dlx loud squealing noise
On a steep decent in 2wd hi or I get a loud squeal as I pick up speed. If I give it just a little throttle it goes away. The machine moves to slow in AWD hi w/the adc for the noise to show up.
Any clues what the problem is?
The dealer said I should be in low gear AWD on a steep hill.
some added info, the dealer replaced the driven clutch because it had the wrong one in it and I would hit the rev limiter at half throttle
Old Oct 15, 2007 | 08:57 AM
From what you've described it does sound like the engine braking system or some part of the brake system. Does the sound come from the front or rear of the vehicle? I would also try the steep downhill in low to see if it squeals then. I heard a similar noise when I was in 2 hi going down a pretty steep hill. But, my quads only have the regular EBS, not the ADC.
Old Oct 15, 2007 | 10:47 AM
Nix377's Avatar
No noise in low, it goes to slow. Don't hear the sound even in hi until I build up some speed. In AWD I can feel the adc kick in and it crawls nice and slow
Old Oct 15, 2007 | 10:53 AM
sheepdogMSP8117's Avatar
My 800 has some gear whine at cruising speeds under light load. I wouldn't call it a squeal though.
Old Oct 15, 2007 | 11:03 AM
Nix377's Avatar
Definitely a squeal (sounds like a belt squeal)
Old Oct 15, 2007 | 04:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it is belt noise. mine does the same thing only when its in high and not in low.
Old Oct 16, 2007 | 08:09 AM
Nix377's Avatar
stendori... mine does in hi not in low also. Is it normal?? My 05 500 ho never did it on the same hill.
Old Oct 16, 2007 | 12:41 PM
RickCJ7's Avatar
The belt will start to squeal as it wears! It is starting to wear and stretch. The belt is slipping on the ebs one way bearing as you go down the hill.
Of coarse you should be in low range if the hill is steep enough to need EBS/ADC.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
