300 TRX Blown engine??
Old Oct 15, 2007 | 04:10 PM
rodchuck's Avatar
Default 300 TRX Blown engine??
I have a 1988 300 TRX (fourtrax) with MANY hours/miles on it, but has always ran great for the most part. A little after I changed the oil it just started making a pinging/whistling noise coming from the motor and now doesn't run too well. I checked the oil and noticed a white, milky substance all over the dipstick and in the crankcase. It can't be water, because I did not drive through any and it is air cooled. Could I have gas getting into the oil somewhere??
Any ideas would be great. Thank You.
Old Oct 15, 2007 | 06:28 PM
BioWare's Avatar
Toxic Ryder
I don't think that it would be gas. I does not take much for water to get in a motor. I would drain the oil and start fresh with some new. Let us know how it goes. Hey welcome to the forums.
Old Oct 17, 2007 | 11:32 AM
rodchuck's Avatar
I can't believe I did this, but I put the oil filter in backwards!! I guess that after doing oil and filter changes for 20 years on this thing, I just wan't paying attention since I had only 5 minutes to do it and had done it so many times before. I am an IDIOT!!
Luckily I only ran it for about 5 minutes this way. I still have great compression, but I have a loud ticking/knocking sound coming from the top end of the engine. Did I wreck the valves or maybe the timing chain?? What should I look for if I pull off the head and take a look?? Thanks for any advice.
Old Oct 17, 2007 | 12:25 PM
BioWare's Avatar
Toxic Ryder
If it is knocking really bad, i would adjust the valves and check the timing chain. What kind of oil do you use. Just hope that the motor does not need to be rebuilt.
Old Oct 17, 2007 | 12:26 PM
BioWare's Avatar
Toxic Ryder
I forgot, welcome to the forums.
Old Oct 17, 2007 | 02:42 PM
rodchuck's Avatar
Thanks for your thoughts. I use Castro 10w 40 oil. I'll take a look at the valves and chain this weekend and let you know how it went. Do you know what the valve clearance specs for this would be?? 1988 300 TRX Fourtrax. Thanks.
Old Oct 17, 2007 | 02:51 PM
BioWare's Avatar
Toxic Ryder
You could call your local dealer and ask what the clearance would be.
Old Oct 17, 2007 | 05:16 PM
HONDA CRUSHER 93's Avatar
mine was making a knocking noise, and loosing power so i took the head off and couldn't find anything wrong, but luckily i had a brand new complete top end to put in it (found in a junkyard in a sealed box.) i put it on there and she runs great now. hope you don't have to do the same. welcome to the forums.
Old Oct 17, 2007 | 08:57 PM
500quadvalley's Avatar
Just wanted to tell you to pull cam cover most likely back cam journal worn.
Old Oct 17, 2007 | 09:10 PM
IronHorseman's Avatar
Don't be too hard on yourself there rodchuck, we've all had our moments. lol
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
