Tail lights melting - Sportsman 500 EFI Stealth /2007
Old Oct 16, 2007 | 01:08 PM
MOOSELIPS's Avatar
Default Tail lights melting - Sportsman 500 EFI Stealth /2007
Bulbs in tail lights heat up so hot the actual bulbs (two piece bulb) are melting, and melting the tail lights? Voltage readings are normal, any ideas why?
Old Oct 16, 2007 | 04:11 PM
sjbr549's Avatar
could have higher wattage bulb in causing the heat build up
Old Oct 16, 2007 | 04:18 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums Mooselips.
Is this a new quad? If not new, did you or the previous owners add something like a winch or extra lights that would have used existing wires in the hareness?
Old Oct 16, 2007 | 04:53 PM
sheepdogMSP8117's Avatar
I'd replace them with stock bulbs and see if it does it then.
Old Oct 16, 2007 | 05:41 PM
MOOSELIPS's Avatar
Yes, quad is five months old, Dealership is going to take care of it under warranty, but wants to advise Polaris. Found no grounding problems, no voltage problems, and bulbs were Polaris stock. Weird! Never seen anything like it.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Oct 16, 2007 | 07:19 PM
SCRAMMYTODD's Avatar
Are your brake lights stuck on??
Old Oct 16, 2007 | 09:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i beleave there only a 37 watt bulb so it really shouldnt be that hot unless like scrammy said brake lights sticking on. what about the bulbs not being pushed in far enough being to close to the lenses cover?
Old Oct 19, 2007 | 09:32 PM
MOOSELIPS's Avatar
Dealership went back to Polaris Industries, apparently there has been quite a few reports of the same problem. Polaris is looking into it and may do recall. Bulb burns hot and not enough clearance in taillight.
Polaris is replacing free of charge all new parts.
Old Oct 19, 2007 | 10:20 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
What year is your 500 EFI??.............Caper........
Old Oct 19, 2007 | 11:55 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Had 07 500 EFI that melted tailight bulb's. Warranty took care of. Dealer was clueless as to why that happened. No mod's other than winch. I took care of that and got an 07 800 Stealth....LOL. 500 was great machine, but once you drive the 8 the 500 is nuthin but late. Is that a stupid line or what, but that,s all I had at the time. Anyway ride safe. Hoov
