Kodiak headlights.
Old Jan 6, 2001 | 04:44 PM
TheQuadfather's Avatar
I have one headlight on low beams, and when I switch to high beams, no headlights. Are these just bulbs, like in a flashlight, or do I need whole new lights? Any help is appreciated.
Old Jan 6, 2001 | 05:47 PM
mr.bill's Avatar
Quadfather, when on low beams does BOTH headlights come on? Or do you already have one burned out headlight( low & high beam filaments).
If both headlights come on then go off when switching to High beam, i wonder about the switch?
It seems unlikely that both headlights would go out at the same time on high beam only.
Old Jan 7, 2001 | 12:49 AM
I get one light on with the low beams, none with the high beams.
Old Jan 7, 2001 | 07:51 AM
mr.bill's Avatar
Sounds like the bulbs. I quess remove them and check continuity of the filaments. Seems to early for bulbs to be going out. I wonder if different vendors make these.
Old Jan 7, 2001 | 06:53 PM
87_250R's Avatar
hay you could use a tester to see if there is power there.
Old Jan 8, 2001 | 08:25 PM
therock's Avatar
Be Carefull when removing the lamps. A friend of mine had the flange break off and the bulb fell inside. It is a real Bi#$ch to remove the light assymbly.
It happend to a friend of mine's Y2Kodiak.
Old Jan 11, 2001 | 01:40 PM
skilsaw's Avatar
A few weeks ago I noticed I had a headlight out so I bought a new bulb. Before installing, I had been on a short ride, and further noticed I had high beam only on one side and low beam only on the other, and either would flicker while riding. Very strange, thought maybe a grounding problem. Removed both lights, and one bulb didn't seem to fit snug. Replaced the bulb, and all problems disappeared.
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
