uni filter NOT HELPING?
Old Oct 21, 2007 | 07:08 PM
zerilious's Avatar
Default uni filter NOT HELPING?
I finally went and bought me and new uni filter for my 330 trailboss knowing I wouldnt get much more performance from this but just the cost effectivness of the cleaning of the filters so I put it on and my bike runs worse it like has not as much power as before I put the filter and ideas am I going to have to rejet?
IM at a loss I have no idea why it would run worse
Old Oct 21, 2007 | 08:32 PM
Jayblazer's Avatar
yes you have to rejet you are now running lean because you have more air then fuel
in the carb you need to rejet to allow for more fuel.
Old Oct 22, 2007 | 04:09 AM
MNpinetree's Avatar
I wld think as rich as they run from factory putting a higher flow filter wld even it out. Dont know much about the uni filter I asume it is a wash re oil type, did you over oil it? More info on how it is running prob wld help others help you out.
Old Oct 23, 2007 | 09:11 PM
dirtsnow's Avatar
I did not have to rejet when I put the uni filters on both my
machines they were already rich enough, BUT this does not mean
u won't have too. U could put your stock filter back on a see if it
goes back to running good just to be sure, if it does sounds like
u need to rejet. one other thing could be if u oiled the filter very
heavy it may be sucking some oil in the motor but it should start
to let up & run better after a while. u want it oiled well but too much
may start too block some of the air.
Raccar1
Jun 18, 2015 02:17 AM
robj
Jun 15, 2015 08:45 PM
lilgirlblue
Nov 23, 2000 03:23 AM
kahoona
Sep 9, 2000 01:27 PM
damguy
Jul 30, 2000 07:59 PM
