Installing 4-stroke pipes
Old Dec 4, 1999 | 08:31 PM
Evan Johnson's Avatar
Can anybody tell me the steps to installing a 4-stroke pipe on a 400ex or other 4-stroke
Evan Johnson 88 LT250R 99 400EX
Old Dec 4, 1999 | 08:35 PM
BONER's Avatar
So you finnaly got that 400ex.
Old Dec 4, 1999 | 09:34 PM
hot_shoe_cv's Avatar
Evan there's really no particular steps involved. Did you get the full system with header pipe or just the exhaust & silencer?
Either way it's just a matter of unbolting the stock one & bolting up the new one. Hopefully the new one will match up with the hangers on the quad. Be sure to rejet your main when you add the pipe.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Dec 5, 1999 | 01:11 PM
trx430ex's Avatar
On the EX it can be a bit tricky.With my LRD pipe, I had to unbolt the remote oil tank and prop it forward.After first draining the oil.Then work the head pipe into position, Then get both header pipes to enter the head at the same time.
After that, Put anti-seize on the studs.Then tighten the studs down uniformaly to get a good seat on the head. (Don't over tighten) As for the hangers they lined up pretty good.
Then re-install the oil tank and change the oil while your at it.
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
2many2ride
Sep 27, 2015 04:35 AM
greg86hd
Sep 16, 2015 12:32 AM
