660R engine noise
Old Oct 24, 2007 | 07:59 PM
sina518's Avatar
Default 660R engine noise
okay so i have a 2003 raptor 660R. i changed my oil, and afterwards about 2 days later i started to get engine noise mostly when i rev. not hard just slightly reving. but now i notice it through the gears too and sometimes at idel. its this knocking/ clinging noise. im worried b/c im not good with bikes as far as problems. first i thought it was the gas so i filled it up with 93 octane, but now i think i might need a valve adjustment but idk.
Old Oct 25, 2007 | 10:25 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Welcome to the forums sina518. Well there could be tons of different things causing those symptoms. If it started after the oil change I'd keep a close eye on the oil level on the dipstick and make sure its not over/under filled. I've heard that early 660's had serious tranny problems I'm not sure what years but pray its not that.
Old Oct 25, 2007 | 11:56 AM
03bansh33's Avatar
the 2001 rappy is the one with bad tranny
Old Oct 25, 2007 | 02:42 PM
sina518's Avatar
yea only the 2001 has tranny problems, but i have been checking the oil and the level is fine
Old Oct 28, 2007 | 12:35 AM
HappaRap's Avatar
Lazy Boy Rider!
87 Octane is fine with that motor. I'd adjust the valves [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 28, 2007 | 12:38 AM
STRAIGHTUPDAHILL's Avatar
did you check oil pressure after the change to make sure it got primed...
note...don't ever change your oil without running an engine first.....
Old Oct 28, 2007 | 12:41 AM
and once your done let it idle for a bit...don't just stomp on it
Old Oct 28, 2007 | 12:33 PM
skramblr's Avatar
Most common - valve adjustment needed. But it could be a million other things...
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
blpersinger
Jul 15, 2015 09:56 PM
D-Hagz
Jul 4, 2015 02:19 AM
