250x engine problems
Old Oct 26, 2007 | 01:09 AM
dan92's Avatar
Default 250x engine problems
i bought a 87 250x not running. when i kicked it over it makes a clanking noise. so i took the top end off to see whats up. to me it looks like every thing is still good. befor i pulled the head off i pulled on the timing chain and it was really loose and the tensioner was all the way in. also when i kick it over there seams to be no compression. does anyone have an idea what might be the problem. has eanyone else had this happen to them.
Old Oct 26, 2007 | 01:27 AM
KNOWSALOT's Avatar
The Facility
The clanking was likely a valve contacting the piston because the engine was not in time. Also inspect for a warped valve and/or a bent rocker arms(s). Both common problems with this engine more than others when the chain stretches that bad.
Old Oct 26, 2007 | 02:36 PM
03bansh33's Avatar
if the cam chain is that loose it has proble jumped time and like KNOWSALOT said you have valves hiting the piston a new cam chain and tenstioner should fix you up if the pisto and valves are ok
Old Oct 26, 2007 | 03:49 PM
dan92's Avatar
thanks. ill get a new chain and put it back together and see what happens
big_g_squared
Jun 28, 2015 04:17 PM
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
kevbowe
Jun 1, 2015 01:17 AM
97TrailBlazer
Apr 2, 2000 03:34 PM
