help
Old Oct 26, 2007 | 12:04 PM
polaris man's Avatar
Default help
200 rancher es put new shift arm and now it seems like the clutch is not wanting to change out of third gear it holds in third and then finally changes how do you adjust the clutch
Old Oct 26, 2007 | 12:23 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default help
There is a Rancher 350 and a Rancher 420, and a Recon 250. There isn't any 200 anything, at least not in current production.
Doesn't anyone have an owner's manual? The procedure is in there and it is extremely simple.
There is a nut on the forward facing part of the engine. Loosen the nut, then turn the shaft with a screw driver. Usually, you will want to turn the adjuster counterclockwise until you just feel some resistance, then back it off 1/4 turn, and retighten the nut.
But, I will bet that this is an ES related problem that has nothing whatsoever to do with the clutch adjustment!
Old Oct 26, 2007 | 10:25 PM
Default help
its a 2000 350 es i have just replaced the shifter arm it shifts fine into 1st and 2nd but when in third it wants to hang up
Old Oct 27, 2007 | 10:23 AM
Mountana's Avatar
Default help
Sounds like you screwed something up......maybe time to take it to the dealer.
Old Oct 27, 2007 | 10:34 AM
Red Rider
Default help
Can you use the manual backup shifter that comes in the tool kit to get it into 3rd-5th gear??? If it will, then you have an ES problem...not a transmission problem.
The whole ES system has been plagued by problems lately. Future buyers would be best to just pass it up. These manual transmissions are pretty much bulletproof, so I am betting it's an ES problem....
